The network has to be up and running. That is why Telia Norway secures it with Roxtec cable seals.
Three main needs make mobile network owner-operator Telia specify Roxtec BG™ B seals for all their base stations built or upgraded after 2014:
- Grounding to avoid costly downtime caused by the effect of lightning strikes
- Protection of equipment from fire and water
- Sealing of more cables, including cables from other operators renting space
Roxtec seals require less space than the formerly used mounting plates with shrink tubing. They also offer built-in spare capacity, which simplifies planning for future needs. Installers just open up seals to add cables, without adding holes or costs. The key to the future is many small sites with a maximized number of cables.
Standardized solution
All contractors use the same optimized kits and the online tool Roxtec Transit Designer™. It helps Telia document all transits and provides information to share with installers. All work is done without special tools or hot work permits. And the shelters are sealed until it is time to route more cables.
30 lightning strikes per month have been registered by Telia in certain parts of Norway.
- Protection against the effect of lightning strikes
- Bonding and grounding
- Water- and air-tightness
- Rodent and insect barrier
- Space efficiency and spare capacity
Download the pdf version of the Telia, Norway case.
Development of telecom base stations all over Norway
Owner and designer
Telia Norway
Sealing and grounding of cable entries in shelters
Requirements
• Watertight
• Fire-proof
• Bonding and grounding
Roxtec BG™ B (bonding and grounding) transits
